Need help with Tune and codes - FirebirdV6.com/CamaroV6.com Message Board
  • Need help with Tune and codes
    I have a 96 Camaro, 3.8 with fully built engine and trans. Running a 97 ECU and have HP Tuners. I have the Intense Nitrous/Blower Cam, 9.5:1 comp, and 24lb injectors.
    Im getting a P0174, P0151, and P0121 code along with a P0300 missfire which may be from the large cam. I do not have any activity on INJ B2, and cant seem to get any. I do have voltage at the injectors but havent gotten a noid light yet to test for them firing. The car has a bad stutter/flutter at part throttle. Ive put new plugs, wires, and TPS on the car. The engine only has 7000 miles on it.
    Steven
    96 w/97 ECU,HP tuners,3.8L Diamond forged pistons,L32 Rods,Intense Stage 3 Nitrous/Blower cam,LS6 VS, Yella Terra 1.6 RRs,Race ported heads,PA K-member,Spohn A arms,tubular LCA and PH,4:10 gears,pacesetter headers, 3" exhaust, NOS 125hp shot,more.
    Re: Need help with Tune and codes
    Have you done a case relearn since installing the engine?
      Not yet.. I have a tune in but its not right yet. I also have a miss , I think its on cyl 6.. Ill know tomorrow for sure.
