L36/26 power - FirebirdV6.com/CamaroV6.com Message Board
L36/26 power
  • L36/26 power
    I'm going to steal the dyno graphs from local members on a different board. Only posting stock L36/26 bottom ends
    L36 Supercharged
    Car still runs like that multiple track days, and daily driven in summer
    L26 Turbo
    low boost with a nasty cam
    Sam3 car more boost, different dyno
    L26 Turbo
    Re: L36/26 power
    L26 Turbo
    L26 Turbo - Manual
      Re: L36/26 power
      I dont get it? is this showing L26's are a better bottom end and making more power? the setups arent all the same?
        Re: L36/26 power
        Different cams, different heads, different turbo, different transmission gear ratios...but all L36/26 bottom.
        I'm just saying that they make power and there's no point putting low compression pistons in your L36 and no need for rods and crank etc. Much cheaper to just buy a junkyard L26 and go from there.
        All those cars were tuned by cartuning with the exception of the first one.
          Re: L36/26 power
          Damn, impressive numbers.
          3M MAFIA
          ________
            Re: L36/26 power
            Originally posted by Meemperor View Post
            L26 Turbo
            Why does the file folder say Jordan_GTP? Im going out on a limb here, but if its a turbo GTP, my guess would be that its either an L67 or L32. If it isn't a GTP, why bother saving the file under that name? Curious....
            1995 Pontiac Firebird
              Re: L36/26 power
              that is one funny lookin dyno graph.
              Dave:
              00 Supercharged Camaro - RIP
              97 Turbo Camaro - Sold
                Re: L36/26 power
                You had a turbo car, would you recommend a stock L36/L26 CR for high amounts of boost?
                  Re: L36/26 power
                  Because the car is a 2004 Comp G.
                  Original motor popped, put in a built motor, chucked a piston and tossed a valve. Then it was on to a stock L26. Motor has been fine since.
                  The graph is funny because of where it starts, and because it's on a Dynapack with lots of load applied.
                  I have a turbo car and I run an L26. It's not about boost, it's about overall HP goals. There is no point with lower compression unless you plan on making over 600+whp, and even then it should be a good amount more.
