Any thread on removing an engine from the bottom? - FirebirdV6.com/CamaroV6.com Message Board
  • Any thread on removing an engine from the bottom?
    I have looked thru about 200 pages under advanced engine and have had no luck. I am starting a rebuild and i have never removed an engine from the bottom of a car and i was wanting to get a thread that has a write up on how to remove the engine from the bottom. So if anyone has a link to a thread on that, it would be very helpfull. Or if anyone has any advice for me on how to take it out the bottom.
    Re: Any thread on removing an engine from the bottom?
    As far as I know I couldn't really find threads but this is how I did it:
    - unhook the engine harness from the forward harness.
    - unhook the engine harness from the inside of the car and pull it through to the engine bay (behind rocker panel in passenger side 3 connections 1 black, 1 blue, 1 white)
    - remove pcm
    - unhook the air box
    - undo the wheel speed sensors plugs
    - take off the starter wire
    - unhook the grounds straps
    - unhook the front brake lines
    - drain the radiator
    - unhook the random vacuum hoses (brake booster and engine harness)
    - remove radiator hoses
    - unhook the ps reservoir and drain it.
    - if you have a trolley or something put under the crossmember
    - unhook the trans cooler lines (auto) drain the fluid
    - unhook the shift linkage (auto)
    - remove the driveshaft
    - pull out the torque arm (these 2 should just fall out when you drop the trans crossmember, you'll lose some trans fluid out of the extension housing seal.
    - we lowered the trans first on a trolley, undo the 4 bolts on the trans crossmember (15 mm)
    - undo the strut towers 2 15mm bolts on each side, then 2 more bolts on the passenger side (15mm),
    - unhook the master cylinder, 2 bolts I believe
    - remove the 2 torx bits under the master cylinder (t47 but a t45 will work)
    - towers should just fall out
    - under the car there are 6 bolts for the subframe, 3 on each side, unbolt them and raise the body off the subframe. Ill get the sizes soon.
    Easy stuff but time consuming
    Ps: I probably missed some stuff I'm eating me some dinner so I did this in a hurry. :)
      Check this out.
      http://www.michiganspeed.com/enginepull/index.html
        Invest in a tractor.
          I wish I had somthing besides a jack and some blocks to lift the body when we did it
            thats funny i have a tractor too i was going to use my come along cuz i dont have a cherry picker but the tractor sound better
