Swap - FirebirdV6.com/CamaroV6.com Message Board
Swap
  • Swap
    Has anyone swapped a vortec 5300 from a silverado into a camaro? If not, is it possible without doing more work than it would take for an ls1?
    Re: Swap
    People do it quite often, same amount of work, cheaper engine to buy however.
    http://www.bowtiev6.com/
      Re: Swap
      Thank you. I just havent seen any threads about it or heard anyone talk about it, so I didnt know for sure. A lot cheaper engine and close to the same numbers as an ls1.
        Re: Swap
        yea go to ls1tech and there are threads in the conversions section ;)
          Re: Swap
          so basically all i need is the 5.3 block with everything else ls1(ie. fuel system, intake, pcm, and everything like that? and technically could bore it out to ls1 specs. All this for almost half the price.
            Re: Swap
            I have the 5.3 in my SS. I LIKE IT!
            Raven
              Re: Swap
              Does it perform like an ls1?
                Re: Swap
                They are only rated about 20 HP lower than the early LS1's.
