fuel pressure regulator - FirebirdV6.com/CamaroV6.com Message Board
  • #31
    Re: fuel pressure regulator
    Thanks, I tried and let the engine run really hot and the fun still not kick on so its better to do the switch mode but I really like to know what is causing the fan fault.
    thanks techsan23
    Alex
    • #32
      thanks techsan23
      Alex
      Check your fan relays and fuses.
      • #33
        I've replaced the t-stat and the coolant sensor 6 weeks ago so I think they are working fine
        also I check the fan fuse switch some relays around (ac relay with fan relay) and still nothing\
        I've check some of the info on the forum but no luck so far.
        Alex
        I did check all, I switch the ac relay with the fan relay and the fuse is ok too, but I replaced it just in case
        • #34
          Will the fans go on high or stay on low?
          • #35
            its on hight but only when the ac is on (i have only one fan)
            • #36
              I forgot your 3.4 motor, then I have no idea, sorry. Good luck with it.
              • #37
                Thanks for trying anyway
                • #38
                  Mine doesn't come on until about 220-230. I have had to replace the fan motor, but sounds like this isn't your problem. Sorry, but I have no other useful info on this subject. :(
                  • #39
                    Thanks, I'm doing the fan switch mod, I think that its a good option specially here in florida.
                    I have a question about the temp sensor:
                    how many sensors a 3.4l have? I know there's one by the t-star on the front top of the block but is there any other?
                    thanks guys
                    • #40
                      Ok guys I found the problem with the rad fan!
                      Looks like is just the temp sensor. THE ONE I'VE REPLACED IN LESS THAN A YEAR AGO!!!!!!
                      I followed some troubleshooting from: http://camaroforums.com/forum/4th-ge...ne-fans-54192/
                      and after unplug the temp sensor the fan starts to work! (of course now the "check engine" light in on all the time)
                      do you think the this problem have anything to do with the raw gas smell?
                      I hope the this problems will go away after replacing the temp sensor again.
                      I'll install the fan switch mod anyway.
                      thanks for your support.
                      Alex
