2002 3.8L swap to 1995 3.8L - FirebirdV6.com/CamaroV6.com Message Board
  • 2002 3.8L swap to 1995 3.8L
    hey guys its been awhile..
    hope everyone is coool. :wavey:
    well back to my question ... (ive searched & research & no luck)
    i came across a complete 2002 3.8l complete minus the transmission with 75,xxxx miles .
    it has the wiring harness and PCM for $200. and im JUST CURIOUS ...
    if i were to someday consider swapping that semi low mileage engine into
    my 'old 1995 3.8 would it bolt up to the 1995 automatic transmission ?
    would it be a direct swap or what are some contributing factors or parts i would need ?
    '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
    Re: 2002 3.8L swap to 1995 3.8L
    swap the upper intake and TB over, and it should be a direct swap. The upper intake is angled on the 95's, and the TB is cable driven on your car.
    The 99+ upper intakes are straight, and the TB is electronically driven.
      This has been covered already, use the search feature for the answers.
        im doing this in about a month lol. Yes just swap the engine not the pcm or wiring.. Use95-97 upper intkae manifold and TB.
        hey another thing out you have to swap its the fuel rails to cause the 98-02 fuel rails are higher or something.
          should be an easy swap. i swapped in a fwd series 3 from a buick into my firebird.
          Team NoVa
            i tried ..
            thanks guys ..
              Hell yea, buy that mofo. You might run into a few SMALL problems but that should always be expected. Id say buy it and when you get the time, Swap it
                :eek:
                  same into my 98 maro. no problems with the swap. just a few accesories shift positions and then i had to paint the thing blue...
