Replacing Heads / Headgaskets - do you have to drop the motor? - FirebirdV6.com/CamaroV6.com Message Board
  • Replacing Heads / Headgaskets - do you have to drop the motor?
    Do you have to pull the motor from the car to change heads or headgaskets on 3.8L's?
    Re: Replacing Heads / Headgaskets - do you have to drop the motor?
    No, you can do the heads with the motor in the car.
      not to thread jack, but can you install head studs with the engine in the car? lol
        yes you can.
        1997 Chevrolet Camaro
        L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
