How hard isit to install one like a JP roller? Any tips?
Those with double roller chains
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: Those with double roller chains
Thanks for the response.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
One more question do I need a case relearn after doing the double roller?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by bigbrian442 View PostYes any time you remove the balancer.
Thats what I thought thanks.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by OneEightSeven View PostSorry to thread jack, but has any one had ANY luck using HPTuners to do CASE relearn? Mine won't work right. I'm in park, brake on, hand brake on, coolant hot, it claims the car is moving (like 1-2mph it shows.)
I haven't done it, but was going to once the double roller is on. Good question.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
My local Chevy dealer did it for FREE.
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Steve, have the crank piece rechamfered!...and use "blue" to make sure it is seated right...many of the dbl roller failures are due to the chain not being 100% straight and pulling on a slightly angle. If you look at your stock crank gear chamfer and the new double roller you'll see the double roller crank gear doesn't have a deep enough lip. Whip it over to a machine shop with your stock piece and have them correct it or you may be regretting it later!
My CASE on HPTuners worked fine - maybe email those guys if you have problems?
For my JP set, the crank gear was way too tight we did a little clearancing and opened the chamfer a bit, been running maybe 30k miles I should pop open the front cover for a look some day (I used the double gasket clearance method, should get a milled oil pump cover)Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
I installed a rollmaster double roller on mine. I didn't modify anything and as far as I can tell there's enough clearance. I've heard no whining or anything of the sort. However, I'll really be able to tell when I pull the cover. It was tight and a pain to get on but it will go if you really line up the two sprockets properly.
TEAM C6V6
Originally posted by Blizzard242 View PostI installed a rollmaster double roller on mine. I didn't modify anything and as far as I can tell there's enough clearance. I've heard no whining or anything of the sort. However, I'll really be able to tell when I pull the cover. It was tight and a pain to get on but it will go if you really line up the two sprockets properly.
Remeber the double rollers are actually built for out australian counterparts irrc, not for us, they are very similar, but this is why the chamfer tends to be out a little.
You won't have any extra hard/easy time getting the chain on/off and there will be no weird noises...the chamfer just affects how the chain sits and lines up because the bottom crank gear can't slid back as far as it should (see the little lip that's on the crank)
Lol, I read about it when I replaced my last motor ans checked it with the blue and sure enough it was the case...quick trip to the machine shop fixed it all up nice lol
You could always pull the front cover and chain and just do it...it's not too hard...afternoon of work maybe? I also swapped out my rollmaster chain for a cloyes chain...I have a brand new dbl roller rollmaster chain sitting here if you need it lol (chain only)
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
