So I dont know why this is happening. I think my pushrods are too big or too long. only 50Lbs of pressure in each cylinder. Car shut off going up road after install. Pretty sure its the pushrods. Just ordered a pushrod checker from intense. We will see then.
Valves staying open after 1x Cam package install
Re: Valves staying open after 1x Cam package install
dont really need a pushrod length checker, just loosen the rocker, if the valve closes then you know that its either because the rockers are too tight, or because the pushrods are too long
I have some stock length pushrods if you need them.1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
I have some used COMP 5/16 pushrods stock length.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by jughead View Postare theyt oil restricted?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Well did a pushrod check measurement. Got 6.98 to 6.97....think previous owner shaved heads, maybe head gasket problem...Would thicker head gaskets help? like .065 or .066 would this help? pleas asap!
.62 is stock, for headgasket08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
