so guys im about to under go the lower and upper intake gasket change because i have a coolant leak so bad that after 45 miles the temp goes up so im about to under go the task sometime this week and anyone wont to give me tips or anything it would help me alot
intake gasket change LOOKKKKK!!!!!
Re: intake gasket change LOOKKKKK!!!!!
Just take your time and try not to get too frustrated. Good luck.1997 Chevrolet Camaro
Its not that bad, just not a whole lot of room to work getting the back bolts out of the uim.1997 Chevrolet Camaro
omg ronniew i wish i would have seen that before i started because i thought my ignition mount was stuck and pryed on it a little and it smaped so i gess i got to ffind a new one and one of my injecter yellow paper like seals at the bottom broke because i had to take it out for clearence so new injester seals new iinjector clip(i lost it but i lost a intake blt to so i got to find the bolt) but i also neew the plastic elbow off my tensioner it disenergrated when i took the intake off but i think ima get everything dipped and cleaned
Originally posted by 3.8lcoty View Postomg ronniew i wish i would have seen that before i started because i thought my ignition mount was stuck and pryed on it a little and it smaped so i gess i got to ffind a new one and one of my injecter yellow paper like seals at the bottom broke because i had to take it out for clearence so new injester seals new iinjector clip(i lost it but i lost a intake blt to so i got to find the bolt) but i also neew the plastic elbow off my tensioner it disenergrated when i took the intake off but i think ima get everything dipped and cleaned
I broke mine off before found one on ebay cheap, good luck with it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
okaay for the retard,he said he dosent know how to upload a picture so i said tiny pic its a web site used for putting pictures on message boards and i said up load it to tiny pic because you pick a picture from your computer and it up loads then it shows you some codes and you pick the one for message boards and put it in your reply
do you understand now
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
