L26 timing chains - FirebirdV6.com/CamaroV6.com Message Board
L26 timing chains
  • L26 timing chains
    Since I snapped a timing chain and wiped out my valves I've found the cheapest route is to just replace the long block and change over my go fast parts.
    Does anyone know if an aftermarket L36/L67 timing chain will fit on a Series III block?
    Re: L26 timing chains
    ZZP will have a Rollmaster that will work for ya.
      Looks like they they are interchangeable.
      So which is better JP performance of Rollmaster?
        Rollmaster , JP has had too many problems to risk it.
