So i have a 95-96 upper intake and throttle body for my 01 3.8 (which had a different upper intake and throttle body)(Straight and DBW). But the question here is will the fuel rail from the 01 motor work on my 96 upper intake. im pretty sure it will as long as i dont use the injectors from the 01 motor which is not a problem cause im ordering aftermarket ones anyway. If anyone knows for sure or has used it on a 95-96 let me know thank you.
Fuel Rail....
Re: Fuel Rail....
You should br able to look at them and tell ifits not going to work, mostly it will since the problem with them before was the height of the injectotrs.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Rail....
Originally posted by ssms5411 View PostYou should br able to look at them and tell ifits not going to work, mostly it will since the problem with them before was the height of the injectotrs.
Re: Fuel Rail....
Originally posted by Unique96Camaro View Postyeah im pretty sure the only issue is with the injectors not the rail its self08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Rail....
Originally posted by ssms5411 View PostI have 1 right in front of me and I remember the problem was with injectors themselves, so you should be good. Did you find a place yet that will sell you the right injectors you need?
Re: Fuel Rail....
I think it will take awhile to get those 80lb injectors tuned in , so I would wait and see how they do. Its going to take some time to get then tunned right.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Rail....
Originally posted by ssms5411 View PostI think it will take awhile to get those 80lb injectors tuned in , so I would wait and see how they do. Its going to take some time to get then tunned right.
Unless you think you can help me out with hp tuners to where i can get the engine running right with the turbo. cause i have know idea how to do it.
Re: Fuel Rail....
No to pcm4less or intense for tunning, they do basic mods, the tunning your looking into is way more time consumiing. To tune your car right , do your first start up and make sure everything works good. Once the turbo is on you willl have to do the tunning or have soone who knows help you. So either way your going to be doing tuning. You can't just take the pcm out and send it to be flash and it works, not going to happen. Safe bet would when its all done go to a good dyno so they know what their doing, do most your wot runs down to just crusing, this way it won't blow up anything. So get to the reading how to tune writeups.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Rail....
Originally posted by ssms5411 View PostNo to pcm4less or intense for tunning, they do basic mods, the tunning your looking into is way more time consumiing. To tune your car right , do your first start up and make sure everything works good. Once the turbo is on you willl have to do the tunning or have soone who knows help you. So either way your going to be doing tuning. You can't just take the pcm out and send it to be flash and it works, not going to happen. Safe bet would when its all done go to a good dyno so they know what their doing, do most your wot runs down to just crusing, this way it won't blow up anything. So get to the reading how to tune writeups.
Can i do my first start up with the turbo on?
and what do you mean by when its all done, do you mean the build its self, and take it over their on a trailer?
""Safe bet would when its all done go to a good dyno so they know what their doing,""
Re: Fuel Rail....
just all the basic stuff for start up, you should be fine then having it on a trailor. After the dyno sesssion ,they should have it streetable that day. I would think.LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Rail....
Originally posted by ssms5411 View Postjust all the basic stuff for start up, you should be fine then having it on a trailor. After the dyno sesssion ,they should have it streetable that day. I would think.LOL
Re: Fuel Rail....
You can have it feeding into the engine just rev, it and check for leaks, just don't go fullthrottle once its on, use the trailor to take it down to get tunned , shouldn't take more than a hour to have a sreetable tune on it for driving around. You put alot of money in to it so better safe than sorry.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Fuel Rail....
Originally posted by ssms5411 View PostYou can have it feeding into the engine just rev, it and check for leaks, just don't go fullthrottle once its on, use the trailor to take it down to get tunned , shouldn't take more than a hour to have a sreetable tune on it for driving around. You put alot of money in to it so better safe than sorry.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
