Fuel Rail.... - FirebirdV6.com/CamaroV6.com Message Board
Fuel Rail....
  • #16
    Re: Fuel Rail....
    No , he drove around not going into boost, this where the dyno could help, you could do it all on the dyno to get it tuned in, and then do some Wot runs on there to so you could setup your timing under Wot.
    • #17
      Re: Fuel Rail....
      o alright, so idk if i asked already but will the car start up right away with the mods done to it ( bigger injectors, fuel pump, cam, stuff like that) with no tuning? Or do i need to tune it a bit before i do the first start? (Without the turbo attached) And im guessing it will run bad, them tune it in with the car started and reving it?
      • #18
        Re: Fuel Rail....
        Its up to you, I would turn the idle up some so it doesn't throw and PO300 codes. I would def. tune it on the dyno, though
        • #19
          Re: Fuel Rail....
          so on start up put the idle up a bit? and i will get it dyno tuned just i want to at least get the motor running some what ok without the turbo feeding into it.
          • #20
            Re: Fuel Rail....
            How hard is the hot wire kit install?
            • #21
              Re: Fuel Rail....
              I have never ran it or seen a write up on it so I don't know.
              • #22
                Re: Fuel Rail....
                what about this one??
                • #23
                  Re: Fuel Rail....
                  If you don't have the turbo on it then run it as you like.
                  • #24
                    Re: Fuel Rail....
                    o alright so just the boost coming from the turbo will mess up the maf and cause the engine to freak out right? possibly causing KR right? but without the boost the car will start and run fine cause its still reading the stock air going through the maf not messing with the computer. correct??
                    • #25
                      Re: Fuel Rail....
                      Yes...
                      • #26
                        Re: Fuel Rail....
                        Yes...
                        alright why the dots, im missing certian stuff huh:o
                        • #27
                          Re: Fuel Rail....
                          Because you have to have atleast 5 letters to respond.
                          • #28
                            Re: Fuel Rail....
                            haha really ive never typed less then a whole sentence good to know haha.
