tick at 2000 rpm - FirebirdV6.com/CamaroV6.com Message Board
tick at 2000 rpm
  • tick at 2000 rpm
    so i just wont some advise i think it might just be i need a oil change because its about that time but it sounds like a fast high tick at 2000 rpm so oil change asap just to make sure i dont f something up
    Re: tick at 2000 rpm
    sounds like maybe an exhaust leak??
      maybe because it sounds like its right in front of me
        I would say exhuast leak.
          My car the same, since people were stupid and took it to a shop and they put too much stress on the manifold bolts.
            well see thie thing is that when i first start my car in the morning the oil pressure is like 70 and i can hear the tick but when i drive a little and the engine heats up and the pressure drops back down to 60 i cant hear it
              Probably unrelated to oil pressure, but related to engine temp. Maybe your hearing some lifter noise until your oil warms up and becomes a little less viscous. The noise shouldn't be a problem unless you hear it when the engine is fully warmed up.
