Is my LIM still leaking - FirebirdV6.com/CamaroV6.com Message Board
  • Is my LIM still leaking
    My lim was leaking oil so I recently did it over again in my 3.4. I put black gasket maker in the valleys and bolted it back up now here is the thing. Asa I finished I cranked it and let it run for about 5 seconds to make sure I did it right then I shut off te car and let it sit 24 hours... do you think my gasket I made gave away. Everytime I drive and stop I can look under my car and see about 3 spots of oil everytime
    Re: Is my LIM still leaking
    The best way to tell would be to get under there and take a look.
    TEAM C6V6
      Oil out of a LIM gasket? Doesn't seem quite right to me, but I don't know jack about 3.4's.
        You should use GM gray sealant on the LIM.
          So you don't think the valley gasket gave way when I cranked it?
