engine surge - FirebirdV6.com/CamaroV6.com Message Board
engine surge
  • engine surge
    94 Firebird
    L32 60*v6
    Megasquirt
    Inovate Wb o2
    stock fuel system
    Ok I recently had a replacement motor put in my bird and since doing so the engine surges from idle to about half throttle when using the stock computer. Its is a cyclic drop about every 2 seconds where it sounds like it just shuts off then picks right back up. During the drop the pressure jumps in the manifold and the engine goes rich then returns to normal. If I unplug the IAC it dose not change anything. Also if I floor it or cruise at 55 or more I don't get the surges. If i use mega squirt it also dose not surge but i think it just died on me.
    Im lost here thanks for the help guys
    Re: engine surge
    I don't know about 3.4's but does it have a IAC?
      Re: engine surge
      It dose but I replaced the IAC with no improvement
        Re: engine surge
        How about vaccum leak, might cause a surge. I'm just throwiing out ideas.
          Re: engine surge
          I don't hear a leak but I will check again
            Re: engine surge
            no leak that i can find
              Re: engine surge
              Have you tried ICM and MAP?
                Re: engine surge
                ICM is good it works under the control of megasquirt sending the same signal. I'll have some free time tomorrow to swap maps.
                  Re: engine surge
                  How about TPS sensor?
                    Re: engine surge
                    The trans still shifts well and megasquirt displayed it just like before the motor swap. Ill still try it tomorrow though
