Hey everyone!
Ok so here is what is going on, The 1997 Camaro 3.8L V6 has been running hot for a day or so, I just replaced the water pump thinking it was blowing out of the weep hole it was not that, I have figured out what it is but I am stumped about how to fix it basically on the bracket that holds the tensioner and the alternator as well as the two large radiator hoses on the passenger side, but there is a 90 degree hose that comes out of the block and into the bracket from what I can tell it is called the water heater inlet hose. it is not cracked or anything it just does not have a tight seal around the hole... but if you know what I am talking about and have fixed it please help me I am stumped!
