ive been offered a set of ported, built heads that have been deck .025". That seems like a lot and i'd be worried about valve clearance, but I dont know machine shop specs and they may still be fine. I need to know before I purchase them. Thanks guys
How much can be decked?
Re: How much can be decked?
depends on your combo...whats done to your motor currently? I know guys that have decked the heads .060
Also, what are the future plans for the motor?
I think you'll be fine with the clearance, I used MLS .065 gaskets on mine, turned out great that was with .020 clearanace on the heads.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
with a stock cam I would think you would be fine...check your clearances though...if the blocks out, put clay on the piston, bolt the block to the head with the same size thickness headgaskets you are going to use, and measure your clearance
ARP head studs would be a good form of insurance as well. You start pulling too much material off these heads and they just don't have the same support, yielding a blown headgasket or warped heads in general.
Check clearances as stated above, run a proper headgasket as well as make sure the valvetrain will have the correct preload.
I would say you'll most likely be fine with a stock cam, but you should always check anyways...the thicker MLS headgaskets that you get from zzp or intense racing will work, but that kind of defeats the purpose of decking the head...
Originally posted by LETZRIDE View PostI would say you'll most likely be fine with a stock cam, but you should always check anyways...the thicker MLS headgaskets that you get from zzp or intense racing will work, but that kind of defeats the purpose of decking the head...
You'll be fine with 105lb springs.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
