So I have a couple parts to my question. Part one: are there any cams out there for our v6s that cause quite a bit of lope? I love the sound but all of the ones I have found on comp cams and everywhere only have smooth idle. Part two: will this cam need major modifications (the springs lifters injectors)?
GT and GT2 cams will have a lobe to them, my VS cam has a small lobe to it , most cams I would do at least 105lb spings and some pushrods, stay away from light weight pushrods, they seem to bend easy.
timing chain is usually a good idea when you're down there. and you're going to have to reseal everything that you are pulling apart
Wait, Is that a V6 or V8? 1990 Chevrolet C-K 1500 series 4.3L .. 5spd
1994 JDM Euno Roadster 1.8L 5spd Bolt Ons.. etc 2000 Camaro 3.8L Auto Bolt Ons..etc
