So I got my exhaust done and now I notice coolant under the car , leaking at the head gasket right on the drivers front area whee the first head stud is at , going to pull the stud out and try to reseal it with paste and put it back in , I hope it seals it up. Or should I remove the head and redo all of them?
Damm Head gasket........................................
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
Re: Damm Head gasket........................................
You will have to re-torque all the bolts now :mad:
Well you may not HAVE to but I would lol. I use the yellow teflon tape and have never had a problem, although people say you're not supposed to use the tape, it has always worked for me without issue.
Originally posted by Meemperor View PostYou will have to re-torque all the bolts now :mad:
Well you may not HAVE to but I would lol. I use the yellow teflon tape and have never had a problem, although people say you're not supposed to use the tape, it has always worked for me without issue.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by whitdog54 View Posttruck motor swap time08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
You think I should pull the head?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Before pulling the bolt out see if you cant put 60lbs of torque and tighten it a bit. I wouldnt go over 80 lbs. See if that helps, if not then pull the bolt out. If it looks like you may have to pull the head i see no harm in trying to tighten the bolt before you pull it. May actually save you from having to pull it.Team NoVa
They take 80 FTLBS , that what I re TQ at. Will try it out tommorow.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostThey take 80 FTLBS , that what I re TQ at. Will try it out tommorow.1995 Pontiac Firebird
I'm hoping for no leaks , if it still does I will have to pull the heads which is no fun in my book.lol08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Either way it looks like you're gonna have to pull the head. Torque it and see what happens.Team NoVa
Got it back together and it looks like its comiing from the LIM and coming down off the corner of the head.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
