can you change the rods from stock to gtp rods/pistons without changing swaping the crank?
camaro 3.8 v6 rods
Re: camaro 3.8 v6 rods
ive got lots dont to it right now, but got a turbo kit on the way and ganna run 20-25lbs of boost.. so ganna strenthen it up.. if your wondering what is done, go to cardomain.com/happyhapka
almost all mods are posted. some i havnt added but at least its most of the work is done.
You'll have to change the pistons to use L67 rods. You'll need L67 or L32 pistons, you can use Diamond pistons also with L32 rods or L67 rods.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...1 day ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....5 days ago
