so can someone with an l26 engine help me by telling me what all i have to do to put a l26 in my camaro
l26 engine install questions??????????????
Re: l26 engine install questions??????????????
I would just search it , theres enough threads on the L26.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
You have to use L36 intake for your TB to work.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
what all should i use or replace when i go to use the l26 block,should i use the l26 cam and rollers and the l36 rods up to l36 heads,and i will probably just get all my l36 parts cleaned like intake heads and i will probably add a double roller
You bolt on your oil pan, intake manifold, front cover, all the accessories, and flexplate.Team NoVa
I used everything from my l26. All I swapped over was the oil pan, intakes, and accessories.1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
Originally posted by 3.8lcoty View Postwhat all should i use or replace when i go to use the l26 block,should i use the l26 cam and rollers and the l36 rods up to l36 heads,and i will probably just get all my l36 parts cleaned like intake heads and i will probably add a double roller1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
I forgot to mention earlier, you have to use the F-Body oil filter deal because the one on the l26 makes the filter point down, and I also used the F-Body oil pickup tube (I can't remember what its called), inside the oil pan. I heard its a little longer than the l26 one.1997 Chevrolet Camaro
Ya just use your oil pan, pick up an oil filter adapter. Use all your accessory but you can keep the l26 balancer. Flip the valve cover so the oil fill is on the pass side of the engine if you want to keep the l26 plastic ones. Use all the f body intake stuff, exhaust manifolds and flexplate.
Knock, cam an crank sensors are the same between the two as are the coils an icm. The icm bracket is different though.
Hope that helps, put an l26 in my 'bird almost a year or so ago now....
Originally posted by Need4Camaro View PostIf I recall correctly everything as far as the internals are the same on the L36 / L26Last edited by MegaHertz; 04-17-2012, 05:21 PM.96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.1 week ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
