ok so i'm new to the forum and i need some help I got a week to get the car together but I have never messed with the push rods and heads on any car.. ...I need to replace the intake gasket and the pushrods go thru the gasket.... Is there anyone in the michigan area that can help me out I really dont want to mess with removing the heads but I dont wanna reuse the gasket any help would be greatly appreciated Thanks
intake gasket/head removal
Re: intake gasket/head removal
This should answer all your question. http://www.dxsoftware.com/magnus/v6headscam.htm
So what are you trying to do? If you just need to do intake gaskets then there is no reason to pull the heads. Whether you have the 3.4 or 3.8 you can do the intake with no issue. The 3.4 requires the rockers to be taken off, but the 3.8 doesnt.Team NoVa
yeah i got the intake gaskets done and had to loosen the rockers and slide the pushrods out for the gasket like noted. Now the car tries to start but is extremely rough sputter instead of running and a slight backfire kind of pop noise.......I didnt mess with the belt or timing at all and I changed the plugs and wires 1-1 so I know that is correct......Is there anyone in the metro-Detroit area that could help me out in person lol Thanks for the feedback please feel free to shoot any help you can preferrably to my email ryan.redmond87@gmail.com......I'm not use to having a account with a forum so I tend to forget about it sometimes.....Thanks everyone
ok so i tightened up the pushrods and it smokes a little bit (smells like gas) and it sputters does a little backfire pop and shuts off......would it be that the injectors are not seated all the way or that the o-rings are worn out and not getting a good seal? I'm far from a mechanic I'm just trying to think of possibilities.....I really need my car running....if you guys have any other ideas please let me know......btw the smoke is coming from the upper manifold and comes out the intake too a little bit.....and i just noticed that I'm missing the line from the back of the intake manifold *behind the fuel rail* and it conects to the brake booster......idk if that would help but I want it there lol......
What year and model is this on?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Its a 3.4 since he said he had to loosen the rockers to pull the pushrods out and change the intake gaskets. That line that goes to the brake booster is a MUST or you have a big intake leak. did you tighten the rockers per the haynes/chilton manual?Team NoVa
ok sorry for posting so much repeatedly but to update i found the big hose from the brake booster to the manifold.....there is a little hose that branches off the T fitting I'm not sure where that one goes but the car still doesn't want to start either......
