I went to check my oil earlier, and when I pulled the dipstick out it was broken off right at the full line. Am I able to put like a big speaker magnet on my oil pan to try and get that piece of metal to stick to it till i can drop the pan, or should I just stop driving the car altogether? The reason Im asking is because this is my only mode of transportation right now. Thanks guys.
Got a little problem
Re: Got a little problem
I wouldn't risk driving it until you get the piece out.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I doubt the magnet would work from outside the pan. It would have to be inside to have the force to attract metal, outside the magnet is basically only going to contact the pan and not be strong enough to attract metal through it (alot of hot rodders put magnets inside just to be safe) unfortunately I think you should pull the pan.....
Ok cool, thanks guys. This sucks.1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
try just dumping the oil? Maybe you'll get lucky and it will come out with the oil?
Yeah I definatly don't wanna drop the k to do it, I'm about due for an oil change anyway so ill try to drain it out first then try the magnet.1997 Chevrolet Camaro
the only issue I see here, is what if a small chip that you dont notice is also around in the motor somewhere...
I'm glad you guys mentioned that, I would've never thought about it.1997 Chevrolet Camaro
