I'm planning to install the Abbott NA Cam in august and I'm replacing the whole valvetrain. I have CompCams 7.05 pushrods, CompCams 105 springs, & zzp modded retainers. In addition I would like to swap the lifters to LS7's. Does that mean I would need new heads or will these fit? Also do I need new lifter trays???
What I described earlier is all I'm replacing, with the exception of gaskets, timing chain, dampener, and bolts of course. So if thats the case I should be ok
Well the original lifters for our cars no longer exist GM uses the ls7's for almost all engines across the board now. And I gathered all 12 now so issue resolved :)
yeah they can withstand the higher rpm's rather well. The comp oe's are good too just more expensive i believe. ZZP sells the LS7's for $109, and I think the OE's are $150
You can find deals on the lifters on LS1tech as well. Think I got mine brand new for 80.00. They are noisy but the LS1 is a noisy engine compared to the 3.8. Do they make the 3.8's sound like a sewing machine as well?
Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
