LS7 Lifters - FirebirdV6.com/CamaroV6.com Message Board
LS7 Lifters
  • LS7 Lifters
    I'm planning to install the Abbott NA Cam in august and I'm replacing the whole valvetrain. I have CompCams 7.05 pushrods, CompCams 105 springs, & zzp modded retainers. In addition I would like to swap the lifters to LS7's. Does that mean I would need new heads or will these fit? Also do I need new lifter trays???
    Re: LS7 Lifters
    LS7 lifters are relatively the same as our stock lifters but pretty much all GM sells now.
    I've got them installed and have zero issues with them you can reuse the stock buckets and all that stuff.
      Re: LS7 Lifters
      Oh that's great so I shouldn't have to worry about pre-load then with what I have?
        Re: LS7 Lifters
        You shouldn't, but I'd doublecheck since you are changing other things in your valvetrain.
          Re: LS7 Lifters
          What I described earlier is all I'm replacing, with the exception of gaskets, timing chain, dampener, and bolts of course. So if thats the case I should be ok
            Re: LS7 Lifters
            Does anyone know where u can buy ls7 lifters by piece and not by set? I got a good deal on a set of 8 so now I just need 4.
              Re: LS7 Lifters
              I thought I read they were the same part # as L36 lifters?
                Re: LS7 Lifters
                Well the original lifters for our cars no longer exist GM uses the ls7's for almost all engines across the board now. And I gathered all 12 now so issue resolved :)
                  Re: LS7 Lifters
                  Makes me feel stupid for buying the comp oe's. I heard the LS7 lifters can sping 6500 stock.
                    Re: LS7 Lifters
                    yeah they can withstand the higher rpm's rather well. The comp oe's are good too just more expensive i believe. ZZP sells the LS7's for $109, and I think the OE's are $150
                      Re: LS7 Lifters
                      I never noticed LS7 lifters on there. Just the Comp OE's and OE-R's.
                        Re: LS7 Lifters
                        Yup only $109
                          Re: LS7 Lifters
                          I have 12 more LS7 lifters if anyone else needs them :)
                          http://www.bowtiev6.com/
                            Re: LS7 Lifters
                            You can find deals on the lifters on LS1tech as well. Think I got mine brand new for 80.00. They are noisy but the LS1 is a noisy engine compared to the 3.8. Do they make the 3.8's sound like a sewing machine as well?
                            Jeff ..
                            1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
                            2002 WS6 T/A.. Bolt ins..448rwhp
                            2009 G8 GT.. Vararam intake, GXP axleback
                            1998 Corvette.. Vararam intake, Ti axleback
                            http://www.fquick.com/slow-v6
                              Re: LS7 Lifters
                              How do the LS7's compare performance-wise to CompCams OE's and OE-R's?
                              aka FreedStyle
                              Chaddrich Freed
                              (1 of 443) 2002 SLP Firebird GT #107 (244rwhp/254rwtq naturally aspirated)
                              2008 Silverado Crew Cab 5.3L 4x4
