Loss of power - FirebirdV6.com/CamaroV6.com Message Board
Loss of power
  • Loss of power
    2 days ago while driving my Firebird it stumbled at about 3k rpm and went back to running fine. I figured this was normal because it will do so on occasion at high throttle and higher rpm's. Since then above 2500 at any throttle the engine tone has changed to a hollow tone but much louder. Also it feels.like it has no power at these settings. Using Megasquirt to monitor it shows a slightly richer mixture but no knocking. This happens both when running the engine with Megasquirt and on the stock computer. Tomorrow I plan to pull the belt and make sure there is nothing binding and to change the lugs for a new plug set
    Re: Loss of power
    How about your cat?
      Re: Loss of power
      It is a possibility. I will check to see if its glowing next time I drive it
        Re: Loss of power
        side note this occurred over 2 days I would think that's a little to fast for such a sudden and severe power loss for a clogged cat
          Re: Loss of power
          Maybe an injector stuck open?
            Re: Loss of power
            fuel mix is reading fine but it I can smell the cat burning after my trip home today so yea its the cat. anyone have a recommendation on a high flow for a reasonable price? Also may buy the headers to go with it if the original fights me coming off the S pipe.
              Re: Loss of power
              I would go with magnaflow but you know those don't last as long as normal cat's you'll have to replace it sooner than a normal one. Headers are always nice:cool:
                Re: Loss of power
                A hollowed out cat is working well for now. About this time next year I will be looking at other mods including headers but I can't afford them just to do it right now
                  Re: Loss of power
                  If your cat is burning up there's other problems causing that.
                  2001 Pewter Firebird Y87, M5
                  Go Sabres!
                    Re: Loss of power
                    other problems such as what? it seems pretty definitive it was a failed cat when stage 1 was hockey puck sized chunks rattling around.
                      Re: Loss of power
                      if something else caused the cat to fail I'd suggest inspecting your spark plug wires. mine were bad and during acceration she'd act like she stalled then restarted herself.
                        Re: Loss of power
                        you could be running really rich which then caused the cat to burn up or it was just time for it to go
                          Re: Loss of power
                          it was just time. 110k miles 16 years and quite a few scrapes from the **** roads here in NY
