So I just ordered my ST5 cam from ZZP , I'm calling my mechanic tomorrow to see how much its going to be to do my head gaskets and to do the cam install. I wish I was healthier so I could do it myself. Its been awhile since I've paid for engine work so I know I'll be shocked. LOL One good thing is he only charges $55 a hour.
ZZP ST5 cam
Re: ZZP ST5 cam
No haven't heard yours, I heard some on youtube though but they were GTPs. Can you post a link to yours?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: ZZP ST5 cam
https://www.youtube.com/watch?v=Pu84xLav0QQ
There's the night I put the new engine in...
Re: ZZP ST5 cam
Yeah I just found it in your FI thread. Did you use MLS head gaskets or stock gaskets?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: ZZP ST5 cam
Originally posted by alex553 View PostNot bad I charge $50 and my customers seem fairly happy with rates. Looking forward to your build, I'm aiming for tens this time around, saving up for a twelve bolt08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: ZZP ST5 cam
Thats pretty impressive for stock gaskets. I'm thinking of reusing the MLS gaskets or might go with the felpros I bought. Will see.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: ZZP ST5 cam
Originally posted by ssms5411 View PostI think I remember seeing your build somewhere but don't remember any details can you post your mods? My memory sucks.
Cars still not broken :banana: it's down due to weight reduction,new turbo,better injectors and fuel pump. Maybe heads and cam
Re: ZZP ST5 cam
Looks good. I know all about hooking up things wrong, when I had the turbo on before I had the wastegate hooked up wrong so on my 10lb spring I was going over 17 lbs of boost so you could say it was running lean.lol My front cover needs replaced(leaks out the oil sender since the threads are stripped so might as well do a cam while its apart.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
