ZZP ST5 cam - FirebirdV6.com/CamaroV6.com Message Board
ZZP ST5 cam
  • ZZP ST5 cam
    So I just ordered my ST5 cam from ZZP , I'm calling my mechanic tomorrow to see how much its going to be to do my head gaskets and to do the cam install. I wish I was healthier so I could do it myself. Its been awhile since I've paid for engine work so I know I'll be shocked. LOL One good thing is he only charges $55 a hour.
    Re: ZZP ST5 cam
    Not bad I charge $50 and my customers seem fairly happy with rates. Looking forward to your build, I'm aiming for tens this time around, saving up for a twelve bolt
      Re: ZZP ST5 cam
      Good god, we charge 86$/hr and are one of the cheapest in the city.
      But you'll love it man. Have you heard any of my old videos?
        Re: ZZP ST5 cam
        No haven't heard yours, I heard some on youtube though but they were GTPs. Can you post a link to yours?
          Re: ZZP ST5 cam
          https://www.youtube.com/watch?v=Pu84xLav0QQ
          There's the night I put the new engine in...
            Re: ZZP ST5 cam
            Yeah I just found it in your FI thread. Did you use MLS head gaskets or stock gaskets?
              Re: ZZP ST5 cam
              I think I remember seeing your build somewhere but don't remember any details can you post your mods? My memory sucks.
                Re: ZZP ST5 cam
                Didn't pull heads.
                  Re: ZZP ST5 cam
                  Thats pretty impressive for stock gaskets. I'm thinking of reusing the MLS gaskets or might go with the felpros I bought. Will see.
                    Re: ZZP ST5 cam
                    Stock rebuilt engine, re used all the torque to yield bolts( I was a broke 17 year old at the time) front facing headers, cheap t3/t4 eBay turbo with a .82 a/r. Stock tranny with a tci 3800 torque converter, 3.23 rear gears with LSD. Lcas and panhard rod,42# injectors,stock fuel pump. I never got the wastegate to open (set up wrong lol)in the two years I ran the car... I would just see my boost gauge pass 15psi
                    Cars still not broken :banana: it's down due to weight reduction,new turbo,better injectors and fuel pump. Maybe heads and cam
                      Re: ZZP ST5 cam
                      Looks good. I know all about hooking up things wrong, when I had the turbo on before I had the wastegate hooked up wrong so on my 10lb spring I was going over 17 lbs of boost so you could say it was running lean.lol My front cover needs replaced(leaks out the oil sender since the threads are stripped so might as well do a cam while its apart.
