Hi All I want to install an Autometer sport comp tach. I'm at a loss on where to run the wires....
Installing a Autometer Tach Need Help!!!!
I think the shift light is the same wiring, when I was a m5. I took the tach signal from the cam sensor, would have to look up which wire but theres only 3. I remember trying it from the pcm to get the signal and the car would die on me so I did the cam wire. Haynes manual has the diagram for which wire to tap into. What is the wiring you need? Power, ground and signal wire correct?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostI think the shift light is the same wiring, when I was a m5. I took the tach signal from the cam sensor, would have to look up which wire but theres only 3. I remember trying it from the pcm to get the signal and the car would die on me so I did the cam wire. Haynes manual has the diagram for which wire to tap into. What is the wiring you need? Power, ground and signal wire correct?Last edited by 6PK...; 09-03-2019, 05:19 PM.
Should be in your instructions. I think Autometer has online instructions as well.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....2 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.2 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
