Ok, so I already knew going into my project that I'd have to replace the tty head bolts and rocker arm bolts. I just realized the connecting rod cap and main bearing cap bolts are also tty and will need replacing. I dont want the arp bit kits from intense or zzp , they require additional machine work. I just want to get replacement gm bolts, and I'm not having much luck finding them. Anyone here know where I can get the gm replacement tty bolts from ?
Replacement bolts
24503056 Crankshaft Cap Bolt (vertical) https://paceperformance.com/i-238752...056-sbolt.html
25531956 Connecting Rod Cap Bolt https://paceperformance.com/i-239190...56-f-bolt.htmlLast edited by FirebirdGT; 03-17-2021, 10:40 PM.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 days ago
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 weeks ago
