So I’m still leaking coolant, I think it’s my front cover, going to double check when it’s alittle warmer, got the Zzp extra thick timing cover gasket and new crank bolt, just need more oil and coolant and should be set.
Leaking front cover
Leaking front cover
96' Camaro M5 to A4 conversion, alot of mods . GT35R Turbo full suspension. Built engineTags: None
I think I’m going to try the GM coolant tabs first to see if it stops the leaking, it’s a small leak. I hate to use a additive but low on funds.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 2.8 Bird View PostIt's not coming from the weep hole of the water pump?
Got the tablets in Thursday, did 3 of them. Was having trouble with getting my temp up at idle, only would go to 179 degrees then fans would kick on. So hooked up Hptuners and turned the fans off . Got to around 195 degrees so my 180 thermostat opened. Will do this a few days then check for leaks.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Got the temp up to 210 a couple of times, cleaned my drip pan. Going to keep an eye on it this week. Hopefully it’s stopped leaking. Starting to warm up so might take it out for a spin.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
So far so good, no coolant on the pan, had a small oil leak too, so tried some STP high mileage with stop leak. So far it’s not leaking.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Still no coolant leaking, smaller oil leak give it another week then I’ll add more. If I can get the cars off the driveway I’ll take it out.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Checked it today and very minimal amount of oil on the drip pan.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
- 1 like
Still leaking a little oil, going to drive it more, says it needs driven 200 miles .08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 days ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...3 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...3 weeks ago
