after I install my cam here in the next month, i want to run either a 75 or 100 shot of nitrous. I was thinking that the GT1 or GT2 cam from ZZP, but I dunno which one would compliment the nitrous for quicker times. I am leaning towards the GT1 since it doesnt set any codes. Also, if anyone knows who can make a custom grind cam to work with nitrous applications that would be cool. Thanks
Best cam to run with a 75-100 shot
2000 Camaro, Pewter Metallic, M5 tranny, 3.23 gears, Hard Top, <br /><br />Modifications:<br />SLP loudmouth (dual/dual tips)<br />MSD 8.5mm wires<br />K&N airfilter<br />SS hood (don\'t buy from fiberglassfabricators.com!!!)<br />Spec stage 2 clutchTags: None
Do you have an LSD? Shifter? Headers? Hi-flow cat? Intake?
[ February 09, 2005, 11:32 PM: Message edited by: 98Camaro3.8 ]Matt
1998 Mystic Teal Camaro M5
well..some people go with naturally aspirated cams such as the GT1 because 99% of the time you are not going to be spraying..and since they do not favor intake or exhaust..performance is usually pretty good with nitrous too..however..if you are looking for a cam specifically for use with nitrous from ZZP i would go with the XP Hot Cam..the specs are very good for nitrous use..lift is not rediculous..LSA is good..it favors exhaust..and some members here have had very good results with it combined with nitrous..if you do not want to do all of the custom tuning required..you can just get a file from www.intense-racing.com ..i believe they make custom grinds and im pretty sure comp cams does too..if you want to save time, money, pain in the @ss then i guess id go with the GT1 since it doesn not require tuning, or valve train mods..Seppo got great results from it but im not sure he sprayed with it..personally..id drop a little extra dough and go with the XP Hot Cam [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Thanks for the help, I plan on running 105lb valve springs and better lifters, retainers and pushrods. Would my car still be smog legal with the GT2 cam? If all the GT2 cam causes is just SES light and has no other adverse effects, ill just go with the GT2.2000 Camaro, Pewter Metallic, M5 tranny, 3.23 gears, Hard Top, <br /><br />Modifications:<br />SLP loudmouth (dual/dual tips)<br />MSD 8.5mm wires<br />K&N airfilter<br />SS hood (don\'t buy from fiberglassfabricators.com!!!)<br />Spec stage 2 clutch
With only a 75-100 shot you dont really need to worry about tailoring your cam specifically to nitrous; that's too small of a shot to really be worried about picking your cam specs around it.
The GT2 would probably be rockin with some tuning. I'm thinking about going that route this summer when I get some more cash.AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...1 week ago
by ssms5411Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...1 week ago
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.2 weeks ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 weeks ago
