I just finished upgrading to 36# GTP injectors. The swap was a pain. I had to shorten the fuel rail supports and cut the Delphi electrical connectors off and solder on Bosch style connectors. However, once done, it ended up being a very nice installation. More importantly, it solved the two problems I was having.
First, I was maxing out my stock injectors. This happened with or wothout the nitrous. When they maxed out the power would stop climbing and the Air Fuel Ratio would go lean (the HP on the dyno peaked and leveled off at 5300 rpms, the exact point the injectors went static). Hopefully, now that the injectors do not max out, there is some more power above 5300 rpms.
Second, I was seeing a strange effect on the injectors when the nitrous was engaged. The injectors would reduce the pulse width, causing the engine to go VERY lean (16.0). With the bigger injectors, the problem has gone away.
I spent $50 on the used GTP injectors and $40 on the connectors. However, if I had to do it again, I would spend the $300 and get Delphi injectors so it would have been plug and play. I would not recomend this mod though I am very happy with the results (the modifications are only needed on 2000+ f-bodies).
This Wednesday it is back to the track and hopefully a new best. We will see.
