I just bought a pair of Heads to port and Polish. I want to clean them up first. What is the best way to clean them. One of my friends said i should soak them in gas for like a week and use brake cleaner and a wire brush. Any suggestions?
Best way to clean heads
1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQTags: None
<blockquote>quote:</font><hr>Originally posted by Gauvin007:
I just bought a pair of Heads to port and Polish. I want to clean them up first. What is the best way to clean them. One of my friends said i should soak them in gas for like a week and use brake cleaner and a wire brush. Any suggestions?<hr></blockquote>
talk to Tiago he can hook you upwww.turbov6camaro.com
1997 3800 Series II Camaro
How clean do you want them? Do not use a wire brush on any gasket surface. You have a good chance of grooving the mating surface and having worse problems down the road. I would just use an engine degreaser and a semi-firm plastic bristled brush. That should be sufficient. Ideally, I would just take it to a garage with a parts washer and see what they would charge to clean them up for you. I't may be worth $20 bucks to not have to deal with it :D<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
a wire brush wont damage the gasket surfaces, aluminum maybe, but not iron...soaking them then brushing them would work fine....<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
why worry about cleaning the ports out???????? its all gonna get ground out when u port them????<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
I would also suggest having them hot tanked.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
<blockquote>quote:</font><hr>Originally posted by WickEdSix9838:
why worry about cleaning the ports out???????? its all gonna get ground out when u port them????<hr></blockquote>
easier to see what you are porting
(i got a set of heads hot tanked for 30$, the machine shop had them for under 24 hours(i dis assembled them))-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
So is the gas bath a good idea?1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQ
Use some simple green to get the oil stuff off. Use a flap wheel to remove the carbon. If you are worried about a little carbon, you probably don't need to be porting your own heads. If it free then hey, go for it, if you have to pay someone, don't bother.
I ported mine and had them cleaned up after.
http://users2.ev1.net/~dee97gtp/gtp/after20.jpg
http://users2.ev1.net/~dee97gtp/gtp/after16.jpg
http://users2.ev1.net/~dee97gtp/gtp/after12.jpg1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
