Best way to clean heads - FirebirdV6.com/CamaroV6.com Message Board
  • Best way to clean heads
    I just bought a pair of Heads to port and Polish. I want to clean them up first. What is the best way to clean them. One of my friends said i should soak them in gas for like a week and use brake cleaner and a wire brush. Any suggestions?
    1997 Firebird M5<br />Bright Red<br />Mods: SLP Intake, Autometer A/F Gauge, Magnaflow CatBack Exhaust, BMR STB, Cragar SS rims W/ Nittos on front and BFG drags on back <br /><br />Stock Dyno Numbers: 170hp and 210lbs TQ
    <blockquote>quote:</font><hr>Originally posted by Gauvin007:
    I just bought a pair of Heads to port and Polish. I want to clean them up first. What is the best way to clean them. One of my friends said i should soak them in gas for like a week and use brake cleaner and a wire brush. Any suggestions?<hr></blockquote>
    talk to Tiago he can hook you up
    www.turbov6camaro.com
    1997 3800 Series II Camaro
      How clean do you want them? Do not use a wire brush on any gasket surface. You have a good chance of grooving the mating surface and having worse problems down the road. I would just use an engine degreaser and a semi-firm plastic bristled brush. That should be sufficient. Ideally, I would just take it to a garage with a parts washer and see what they would charge to clean them up for you. I't may be worth $20 bucks to not have to deal with it :D
        Hot Tank all the way....
        I got mine hot tanked, they did a crappy job, but they still look clean...
        pic
        [ February 04, 2004: Message edited by: AZ3.8Camaro ]</p>
        1997 Dodge Viper GTS
          a wire brush wont damage the gasket surfaces, aluminum maybe, but not iron...soaking them then brushing them would work fine....
            If you're doing the p&p, you want all the crap cleaned out of the ports. The best way to do that is by hot-tanking. Find a local machine shop to do it for you - it's worth the price!
            83 S-10 w/95 3.4 SFI, 4L60E
              why worry about cleaning the ports out???????? its all gonna get ground out when u port them????
                I would also suggest having them hot tanked.
                  <blockquote>quote:</font><hr>Originally posted by WickEdSix9838:
                  why worry about cleaning the ports out???????? its all gonna get ground out when u port them????<hr></blockquote>
                  easier to see what you are porting
                  (i got a set of heads hot tanked for 30$, the machine shop had them for under 24 hours(i dis assembled them))
                    So is the gas bath a good idea?
                      Use some simple green to get the oil stuff off. Use a flap wheel to remove the carbon. If you are worried about a little carbon, you probably don't need to be porting your own heads. If it free then hey, go for it, if you have to pay someone, don't bother.
                      I ported mine and had them cleaned up after.
                      http://users2.ev1.net/~dee97gtp/gtp/after20.jpg
                      http://users2.ev1.net/~dee97gtp/gtp/after16.jpg
                      http://users2.ev1.net/~dee97gtp/gtp/after12.jpg
                      1997 GTP(13.3@104)-Sold<br />1999 Trans Am M6
