1997 PCM, PROGRAMING - FirebirdV6.com/CamaroV6.com Message Board
  • 1997 PCM, PROGRAMING
    please se my sit for all my mods, now for the bigger injectors and such and to make sure i don top off my MAF, should i get the MAFT 2.0 from zzp?
    im thinking with auto taps and the MAFT i can about tune my own a/f ratio with those untill i get to the dyno, and that will great to tune on the dyno tune
    IM REALLY STUCK HERE
    please any help
    the the "tune yor pcm yourself" post only works for 98 and up cars :mad:
    PLEASE HELP
    other turbo SC guys what did you do????
    i really dont want to lean out that would suck
    www.turbov6camaro.com
    1997 3800 Series II Camaro
    Chill out a second. And don't forget this is advanced tech -- your question might fit well in the FI forum.
    When do you realistically expect to have everything delivered, built, installed, and finished, aside from tuning, on your car? Honestly, realistically. There's a sense of urgency in your posts that I haven't understood -- I thought you were a F3 GP'er, and that you were having an engine built.
    For the tuning, I would just slap on Autotap and start watching, then use an FMU (either adjustable or bleed a fixed one down) to fine tune things, along with bigger injectors if needed. Yes, it's sort of a bandaid. And yes, maybe nocutt will be against it ... and yes, you'd fair much better with tuning, a 2 bar MAF, DFI, etc., but I'd say check what's going on when you're ready to drive the car.
    Edit: looking at your mod list, the MSD DIS-4 and BTM will serve you well.
    -Rob
    [ February 04, 2004: Message edited by: Wicked 3800 V6 ]</p>
      <blockquote>quote:</font><hr>Originally posted by Wicked 3800 V6:
      -Rob
      <hr></blockquote>
      well yes the motor is being biult and shold be in the shop before the 15th ofeb, i don;t only need a/f tuneing but my revlimts can go up too, need to turn fans to lower temp and everything.
      but what about just using the MAF translater, to adjust? the fuel curve
        Personally, if I were you, I would look into a FAST system or DFI.
        You seem like you have a killer set up and might be limited... no, you will be limited by the stock PCM.
        It can only be modified soooo much, even with FMU's, MAFT+'s, AFPR's etc.
        I have held off on a cam due to wanting to get the BEST cam/ tuning possible.
          MAFT or MAFT+ isnt gonna work very good on ur setup, all the MAFT does is make it richer or leaner through the whole fuel curve, w/the injectors your car will be either rich down low and lean up high or the other way around....BTW i just read what James said, the only options you have are the aftermarket systems...
          <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
            umm how much do they run? so basiclaaly i won't need my stock PCM anymore with MSD doing the spark and a FAST or DFI fuel system? they just take over? and were can i find them
            a dyno tune will not do the trick??
              Sure it would... You can dyno all day long, but a tune would be hard to come by... They don't make the software.
              1997 Dodge Viper GTS
                <blockquote>quote:</font><hr>Originally posted by AZ3.8Camaro:
                Sure it would... You can dyno all day long, but a tune would be hard to come by... They don't make the software.<hr></blockquote>
                LOL the the dyno i talked to lied to me then :mad:
                they said they could tune everything, a/f ratio, timing curve, max rpm, speed limiter, and fans temp ect ect ect
                  Then you better explain to them that you have a V6 with a turbo kit, and not a V8. Most dynos probably expect you to have a typical V8, for which LT1 / tunercat / HP / LS1edit is freely (as in easily, not free) available.
                  FAST / DFI / TECII, etc, those don't exactly require tuning on a dyno. Many you can plug in, do a simple learn, and they will fire and run. You can then use a laptop to fine tune specific parameters, or run it on auto-learn given a specific goal (i.e. A/F ratio). A setup like that is maybe $1500 - $2000, compared to the 98+ tuning of , what, $500? In the end, it's not "that" much more, depending.
                  Big big big difference is that I can't imagine DFI providing OBD-II support for your local emissions shop.
                  -Rob
                    -Rob
                    <hr></blockquote>
                    ohio = no smog laws
                    [img]graemlins/fluffy.gif[/img]
                    thank but 2000 WAY TO MUCH lol i told the dyno i had a V6 in big bold letters in the email, and told them on the phone 3 times lol
