Well I'm out to desensitize it. Right now, I'm staying away from resistors to desensitize it. My first attempt will include wrapping it with Teflon tape and perhaps a small piece of a old T shirt depending on the exact shape. From what I can tell, I think it's going to be a ring bolted to the block.
Will water start pouring of this hole if I remove the bolt? I've read that on the LT1's it does.
1997 Nassau Blue Vette<br />1989 Jeep Cherokee 4x4 (lifted with 31\" tires)<br />2000 V6 Camaro, loud, cammed 210rwhp *SOLD*
Huh, I posted this in the Intake/Exhaust Forum. I didn't think it was exactly advanced material but guess somebody did.
After looking up a replacement knock sensor from AdvancedAuto, it looks like a bolt with several fat washers on it with a wire coming out the head of the bolt. Looks like I have to use an open head wrench to get this one unless a deep socket will go over that plastic fitting once the wires are pulled out. I can reach this from under the car right and what about the coolant thing?
Im not sure how to desonsotize the knock sensor. But when I do my cam swap I think im gonna have ZZP reprogram my computer, they should be able to desensotize the Knock sensors by the computer. That may be another option for you.
