I am currently starting my planning on a newer 3.8l Camaro, and I have come to the point where I need to start looking at stronger internals.
I am just trying to get some opinions and suggestions on these proposals and plans that I have, because I can't get anything else out of searching the database.
I am looking to running 100 to 150 shot of nitrous to compliment a 100 hp SC (hopefully). My plans are to get forged pistons by Ross Racing Pistons, and the forged connecting rods that are L67 spec. I want to keep the stock compression ratio, but in need of stronger assemblies. If anyone thinks stock compression won't work, I can use the suggestions on what to use.
Second, I plan on getting the SuperSix Power Pak offered by SuperSix motorsports. I can't tell whether or not these heads are milled down or what, but if they are, I needed to know how much they are milled down, and whether or not a thicker head gasket can make up for the loss, considering I want to keep stock compression if possible. I can see that they also have two cams availiable with this package, a cam with a duration of 214/214 110 separation and a cam with 220/224 duration 114 separation. Which cam would be good with the application that I have above, or if there is another cam I should go with, what is it?
I am also looking for rockers that cam compliment this in any way. I no nothing about rockers besides their basic operation, if anyone can tell me what is a good rocker, please tell me, as I will be searching for those too.
Lastly, does anyone know where to get a hardened crank at or who will do work on a crankshaft?
Any suggestions or recommendations are helpful.
