In the process of heads install. - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    you HAVE to pry, just be carefull with the gasket surface [img]smile.gif[/img]
    • #17
      You don't have to pry much, a whack with a rubber hammer usually does the trick. That gasket isn't super sticky. Aluminum will bend easily if you pry too hard. When I removed my lower intake manifold I wrestled the heck out of it and could not get the darn thing off. I was stuck for hours cursing at it. Make sure you got the 2 hidden bolts that are inside the intake, they are in opposite corners.
      There is a bracket that extends down the passengers side and connects to the alternator. For some reason my intake was hung on this bracket and after I removed it the intake came right off. It's only 2 bolts that hold it on and one looks like a star patern inside it but you can get a socket over it. Hopefully that will set your intake free. [img]smile.gif[/img]
      Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
      • #18
        yeah you will have to pry the intake, jsut do it carefully. Crowbar? I think a long screwdriver will suffice. like Tiago said keep as much to gethr as possible, I also like to put stuff sort of back to gether when it is off the car, maybe one or 2 looslely threaded bolts. You will ber amazed how much you forget in the end.
        as for the fule lines, not sure how it is on 3.8L, I jsut kept my fuel lines attached to the fuel rail and injectors, and jsut moved it ot the side with the flexible hoses.
        • #19
          when referring to crowbar, I was thinking of a small one. I have an assortment of different sizes that have nice little rubber handles and would great for that sort of thing. sorry [img]smile.gif[/img]
          2002 Camaro SS 6 Spd<br />Sebring Silver Metallic<br />Still breaking it in<p>Traded in - 2002 V6 5 Spd Camaro.<p>\"I\'ll never trust squirrels again.\"
          • #20
            <blockquote>quote:</font><hr>Originally posted by Ironman24:
            <hr></blockquote>
            Thats what was holding me up were the two hidden bolts on opposite corners. After removing these the manifold came off easily by prying on the front of it. I didnt pry on the gasket part but I pryed a little on the front underneath.
            I now have lower intake off, passenger side exhaust manifold is off. And Passenger side Rocker Arms and pushrods are off. I will pull the heads today sometime after work. Its taking me a long time to do this. I have to keep reading my Haynes manual make sure Im not screwing up. But Its coming along smoothly. No major problems as of yet.
            I was thinking, While I got it all torn apart maybe painting the valve covers and intake manifold. What kind of paing should I use?
            • #21
              i would put some roller rockers on while i had it apart :D
              1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
              • #22
                Roller Rockers would be expensive. And a high ratio rocker wont work with the cam I have selected. I think I will probly just use the stock ones.
                • #23
                  As for paint, get it powder coadet, expensive, yes, take s a while, yes, but worth it. Any other kind of paint is going to burn due to the high heat.
                  -Steve
                  • #24
                    Uhh, why don't you take the heads off then take the rockers off?
                    • #25
                      <blockquote>quote:</font><hr>Originally posted by Cale:
                      Uhh, why don't you take the heads off then take the rockers off?<hr></blockquote>
                      makes no difference. Either way is all the same. I may do that with the other side. But they were pretty easy to get too once everything was out of the way.
                      • #26
                        Just saying.. little easier to put the head on a bench and do it there instead of hurting the ole back anymore by leaning over to do it.
                        • #27
                          Just saying.. little easier to put the head on a bench and do it there instead of hurting the ole back anymore by leaning over to do it.<hr></blockquote>
                          Good point. I am probly going to do that with the other side. I only did it with the passenger side head.
                          • #28
                            What should I clean the intake manifolds off with? There a little dirty?
                            • #29
                              Engine Parts Cleaner.. comes in like a paint gallon at autozone or murrays or pep boys.
                              Or simple green... but parts cleaner works better at breaking down oil.
                              Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
                              • #30
                                I decided to port and polish the upper and lower intakes. I bought me a dremel with several attachments. I starting P&P the lower intake, took me a while to get the hang of it but I have half of the lower intake done. I will have the intakes P&P done by tonight. Hopefully I can have the heads off tommarow.
