DOH! Sorry, mine is a 2000. Thanks Keith!
Paging ALL V6 Aftermarket Camshaft Owners
Do any of you have sound clips of what your car sounds like with the cams in them?
What about some prices?
Sorry if I shouldn't have posted this in here.1998 Firebird w/ LS1 & A Few Mods<br /><br />Pictures--><a href=\"http://www.fad2blk.smugmug.com\" target=\"_blank\">www.fad2blk.smugmug.com</a>
Full Name: Rob Davidson
Car: 1998 Camaro
Engine: L36
Cam Vendor: COMP Cams
Duration @ .050: 206 Intake, 212 Exhaust
Camshaft Lift: .320" intake, .325" Exhuast
Valve Lift: .512" Intake, .520" Exhaust
Lobe Separation: 112
Intake Centerline: 108
Rocker Ratio: 1.6
Engine was built for nitrous but has yet to be installed
[ July 20, 2003: Message edited by: Robafb ]</p>Msd wires,Summit coils,Cuctom CIA&longtubes 2.5inch w/side exit,Cam,Heads & Intake,30# injectors,reprogrammed computer,3400 edge Converter, 3.73\'s&LSD,Edlebrock torque arm, SLP LCA\'s,Jegs panhard bar,16 inch nittos Best ET 14.374 @94 <br />Best 60\' 1.91
I'll try again.
Full Name: Matt Craft
Car: 2000 Camaro
Engine: L36
Duration @ .050: 218 Intake, 218 Exhaust
Camshaft Lift: .330" intake, .330" Exhuast
Valve Lift: .528" Intake, .528" Exhaust
Lobe Separation: 113
Intake Centerline: 110
Rocker Ratio: 1.6<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Everyone, please follow matts example.. That's exactly what I need. I even posted that in the original post.
Why do some of you give me imcomplete information?Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Full Name: Andrew Molenda
Car: 98 Grand Prix
Engine: L36
Cam Vendor: COMP Cams (ZZP)
Duration @ .050: 210 Intake, 210 Exhaust
Camshaft Lift: .317" intake, .317" exhuast
Rocker Ratio: 1.61998 Silvermist GT Coupe<br />1/4 mi 15.19 @ 89 mph (pre-cam)<br />Performance:<br />DHP PCM, <b>ZZP GT cam</b>, ZZP S1 HVTB, ZZP HVIM, Borla Cat-Back Exhaust, Custom DP, no u-bend, no res, 180 T-Stat, FWI <p>Handling:<br />KYB Struts,Buick STBs, ZZP Poly Motor Mounts, Potenza RE 730\'s 245/50/16
Full Name: Aaron Leese
Car: 1993 Camaro
Engine: L32
Cam Vendor: Crane
Duration @ .050: 204 Intake, 214 Exhaust
Camshaft Lift: .282" intake, .282" Exhuast
Valve Lift: .451" Intake, .451" Exhaust
Lobe Separation: 109
Intake Centerline: 105
Rocker Ratio: 1.6-Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
Sorry I just haven't gotten around to updating the page recently, I will soon.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Need to include if the engine is SC, turbo, NOx, or NA. Otherwise comparison is useless.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Excellent point.
If your cam is for an SC car, specify that.. if your car is for an N20 setup, specify that.
I know what cam is for what though. ;)Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Updated the list..
I did not add in a column for blower/N20/Turbo because many of the cams can do both easily.
You can clarify in extreme sitatuations for blower and turbo.. and I guess N20 but nobody here is that extreme yet.
Most likely if you are boosted you will have a high lobe sep to maintain cyl pressure, if you are NA you will have a lower one. N20 it doesn't really matter cause we don't use massive shots (most of us anyway)..
so it is what it is for now.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Full Name: Ryan Crosley
Board User Name: Ryan94V6
Car: 94 Camaro (auto)
Engine: 3.4L V6
Cam Vendor: Crane Cams Powermax 2030
Valve Lift: . 451" intake, .451" exhuast
Lobe serparation: 109
Rocker Ratio: 1.62002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...6 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....2 weeks ago
