206°/212° at .050"
Intake Lift .320" (.512" lift at 1.6:1 rocker ratio)
Exhaust Lift .325" (.520" lift at 1.6:1 rocker ratio)
113 Lobe Separation
(it's the L36 cam from grandprixstore.com)
What else will I need to buy (new rockers, pushrods, etc.), and will I have SES light problems or clearance problems? Thanks in advance...
I know of a guy with a 2000 Firebird that has no problems with this cam (SES lights and such). I would recommend new springs and retainers at the least. New rocker arms and rods are nice if you can afford them. Consider doing more than just the cam if you can, like going with ported heads as well, since it will take advantage of the new cam and will be more worth your time while you have the engine apart =).
