Was told somewhere that LS1 valve springs could be used when buying new ones.. This true? cause I got a price of a whopping 25 bucks for new ones from GM... Will drastically reduce my cost of the new parts I have on tap... they are good for over .55 lift...
LS1 Valve springs??
Yes stock shaped LS1 valve springs work. What GM springs did you get new for 25 bucks?
According to Tbyrne:
stock ls1 are good to .525
01 LS6 .540
02 LS6 .600
SLP .610Keith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
http://seppo.hopto.org/
LS1 valve spring
install 1.800" / 75 lbs
max lift 0.525" / 230 lbs
2001 LS6 valve spring
install 1.800" / 90 lbs
max lift 0.540" / 250 lbs
2002 LS6 valve spring
max lift 0.600" / 300 lbs
SLP valve spring
max lift 0.610" / 320 lbs
The spec's from tbyrne's webpage. http://www.tbyrnemotorsports.com/ls1/ls1valvetrain.htmlKeith - 99 'maro - White M5 - bumpstick and boltons - 13.65 @ 101 N/A
