cam and heads were on the car too, they also had problems so 250+ should not be a problem on a auto and I would think more like 270 on a manual car
4.1 stroker kit still a go?
But is 1900 dollars worth 18HP?2001 Camaro A4<br />Maroon Metallic <br />Y87,Monsoon 500w,TTops<br />Appearance: Silver ZR1s w/ 275\'s<br />Intake: !Air Silencer, FRA Mod, k&n<br />Exhaust: 3\'\' Cat, 3\'\' B&B TriFlo<br />Misc: SLP Fan Switch, 1LE Boxed LCAs <br /> <a href=\"http://www.cardomain.com/id/mshapiro\" target=\"_blank\">http://www.cardomain.com/id/mshapiro</a>
how much do you bore out your engine with the stroker crank to get 4.1 liters96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
The thing is, the FWD car they tested at 240 whp also ran a 13.4 1/4 mile, a RWD car should go aproximately .3-.5 faster. That's potential high 12's. 2k for that kind of potential N/A without doing an LS-1 swap is worth it.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
Heads, cam, stroker kit, labor, tuning, and you might be looking at close to 4-5k.2001 Camaro A4<br />Maroon Metallic <br />Y87,Monsoon 500w,TTops<br />Appearance: Silver ZR1s w/ 275\'s<br />Intake: !Air Silencer, FRA Mod, k&n<br />Exhaust: 3\'\' Cat, 3\'\' B&B TriFlo<br />Misc: SLP Fan Switch, 1LE Boxed LCAs <br /> <a href=\"http://www.cardomain.com/id/mshapiro\" target=\"_blank\">http://www.cardomain.com/id/mshapiro</a>
Originally posted by Tiago:
good **** I wanna turbo one. :D
We tested in a boosted application and raised power until the motor failed. The engine ended up making ~375WHP and well over 400ft/lbs to the wheels before the crank snapped in half! The kits we are shipping now have some minor strength improvements from the original design but we do not recommend using nitrous or boost. The kit was designed for NA applications and therefore the parts are of minimal weight to maximize HP.www.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by Max2k1Camaro:
Heads, cam, stroker kit, labor, tuning, and you might be looking at close to 4-5k.2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
I know that higher shifting isnt required, but since the rotating mass is WAY lighter cant we shift at a higher rpm if we want...did they test to see how high we can shift with this? Thanks2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
umm higher shif point you need to upgrde your vavle springs and rods and lifters.www.turbov6camaro.com
You would probably want to upgrade all that stuff during the rebuild anyway. Especially when upgrading the cam shaft.. :D2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
Originally posted by Timbo1969:
You would probably want to upgrade all that stuff during the rebuild anyway. Especially when upgrading the cam shaft.. :Dwww.turbov6camaro.com
Eh this is of no use to the boost boys :( Higher compression = bad. How can it run mid 13s with only 240whp on a FWD car? LS1s have around 280-290rwhp and they only run mid 13s themselves. Something seems a bit off to me.2002 Black Firebird:<br />A4, Y87, W68, T-tops<br />Best NA ET: 15.16 @ 90<br /> <a href=\"http://members.cardomain.com/darksde02\" target=\"_blank\">http://members.cardomain.com/darksde02</a>
Remember dyno numbers aren't everything. Jason's (Co-owner of TSP) wife's car is a 35th SS, and dyno'd like at or under 300rwhp, and ran a very low 13 even at our altitude (4500+ feet that night). Our last project Z28 car ran 10.78@124mph naturally aspirated...and dyno'd a best of 408rwhp!!! Numbers don't mean you are fast, the setup and combination of parts (even if they dyno low) makes the track times. My $.02<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
would a regular engine setup for a turbo be better than this engine setup for a turbo. what one would be better, i know more ci the more powere but the sight said only 8 or so pounds. also what about the compression. with this kit can you get pistons to make a 8.5 to 1 compressioned 4.1 stroker? i want a turbo and this kit but would this kit be weaker than a regular forged setup on an engine.96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.5 hours ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 days ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....1 week ago
