Injectors and PCM - FirebirdV6.com/CamaroV6.com Message Board
Injectors and PCM
  • Injectors and PCM
    Hey guys, I'm getting ready to install about
    3.5 - 4 lbs. of boost as well as a 75 dry shot of N2O. What size injectors will I need, and how expensive will the total cost be? I suspect that I'll need a 33 or 34 before my mods are all complete. Also I'll be adding the heads/cam on a little later and I'll need PCM recalibration. I e-mailed Ed Wright and he told me that he doesn't work with our late model PCMs, I also e-mailed Magnus and he said he would know of his capabilities next week. Any suggestions on getting my PCM reprogrammed? Thanks.
    2001 A4 Pewter 75th Anniversary W68 Firebird<br />1997 Dodge Ram Extended Cab 360 CID<br />1996 Ford Explorer V6<br /><i><b>Any number you can think of, I can think of one higher.</b></i><br /><a href=\"http://www.criesmusic.com\" target=\"_blank\">www.criesmusic.com</a><br /><a href=\"http://www.mp3.com/beneaththestage\" target=\"_blank\">www.mp3.com/beneaththestage</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar6.jpg</a><br /><a href=\"http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg\" target=\"_blank\">http://www.thenebula.com/carpics/pics/Silver3800V6Picturescar4.jpg</a><br />AIM: Guitarchitect201
    to help fight off an ses light or an overly rich mixture, get an adjustable fpr and crank up the pressure some. also, getting true 22 lb. injectors or 24 lb. injectors should be fine, I think. an s-afc would help you tune the mixture and get it just right.
      You might think of different gears if you're going to have a SC. You're probably not hooking with nittos on the street as it is now.
        Better pray to the gods that Magnus can come through for us. I just put in some 24lb injectors today and the car is WAY rich down low. It's so bad after a WOT run the car will just die, there is so much fuel it can't idle.
        Are you planning on running any kind of FMU for the boost?
        Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
          <blockquote>quote:</font><hr>Originally posted by Ironman24:
          <hr></blockquote>
          I was thinking the same thing. If that nitrous is a wet shot, with a FMU the stock injectors may be able to handle the extra fuel.
          I'd have to run the math to be sure, and I'm too tired at the moment. 16 hour work days tend to make me lazy. [img]tongue.gif[/img]
            hey anyone know how to get the fuel injectors off
            Thanks
            Dakota [img]graemlins/burnout.gif[/img]
            Slammed, Cammed, Stalled, Rollin on ZR1\'s and the sickest exhaust you have ever seen on a camaro Z06 style whoo whoo.<br />I\'m the reaper dude, ask ur people dude. I move
