Got this cam and wanted to know if 1.7 rockers well work
<blockquote>quote:</font><hr>Originally posted by dust ya: Hey guys, got this cam from comp cams and wanted to know if it would be possable to have 1.7 rockers with this cam?
WickedSix from Crane flowed some stock heads and they did not peak until well after .550" lift, STOCK. They were actually pretty impressive completely stock.
My bad all, I did forget to say that i did do head work about two years ago, at that time the guy at the shop said there was no cam for my car at that time. I felt they were give bull....
now that I got one why not, and if i can put 1.7 rocker to get extra lift and I hope it can be done, I'm going to do that to. I know the best people to ask is all of you guys, cause you guys know what you all are talk about. thats a fact. thanks.
<blockquote>quote:</font><hr>Originally posted by Bird_Of_Prey: You guys know that anything over .530 requires the heads to be milled, right?<hr></blockquote>
You do realize that milling the heads will make the valves closer to the piston right? This will in now way make it safer for higher lift.
I ran .528 lift no problem with 105# springs and i had the valve seal pedastools milled.
