I dont know whats wrong i tryied to tdo everything in my knowledge to fix it but the problem is that the car is smoking, choking, all the engine does is stay at idel speed if u give it gas it will just suck air with out nothing really happening, i gave it a tune up about 2 months ago . i put a new egr valve, and i dontknow whats going on . i took it to gm and they said NEW MOTOR just by looking at it shake im like umm you are a geinus now so they did a test and they said its has a low compression? [img]graemlins/bs.gif[/img] which i dont know. but it starts right up in the mornings and everything just no power no rpm's past 1000 serious help needed !!! :mad:
NEED SERIOUS HELP WITH MY 3.4 93 FIREBIRD
First, check all of your vacuum hoses. Once you get that settled, look for other potential leaks, such as a head gasket, etc. Grab a can of carb cleaner, and go to work on the outside and the inside (of the throttle body / etc). You'll likely find a bunch of stuff. And read you codes (which are definitely thrown if you're having that much trouble)
What kind of tranny do you have? That might have gone, not your engine. Either way, hate to say it, but the 93 is now 11 years old ...
-Rob<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
Check the Throttle Position Sensor (TPS). IF the computer is not getting getting a signal, your car will run like sh!t.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
If they said low compression, I would consider getting a compressio testing tool and checking out the compression on each of the cylinders.
does it soudn lock anything is flopping around or maybe like someone dumped a jar full of metal marbles into your motor?
I drove a 2.8L 50 miles with only 5 pistons, the sixth was shattered and in the oil pan [img]smile.gif[/img]
Doesn't sound good. Could have a hole burned in a piston. I'd say before you go spending over 500 bucks on it, seriously consider picking up a junkyard or other used 3.4 motor. They're dirt cheap.\'95 Med. Quasar Blue Camaro 3.4 A4<br />Bunch o\' mods<br /><b>10.18 @ 67.60 mph 2.22 60 ft (1/8 mile)</b> <br /><br />-1986 Camaro with a carbed 350<br /><b>8.53 @ 81.45mph 1.8 60\'</b><br />AIM CamaroL32
sounds like my motor before I got it rebuilt...the piston rings were burned to sh**Car: 1995 Camaro 3.4L V6<br />Mods: K&N FIPK,3 IN. Flowmaster exaust,RKSports headers,ported/polished heads, Eibach lowering springs, RKSports preformance wing, short shifter<p><a href=\"http://www.cardomain.com/id/equis\" target=\"_blank\">http://www.cardomain.com/id/equis</a><p>Don\'t Let Coast Motor Supply Happen To You.<p>Hear The Roar Of The 3.4
if you need a new motor...i would either see how much it will cost to get fixed, or go for a v8/ lt1 motor instead. Is this car your daily driver?94 3.4L A4 white t-tops<br />moroso cai<br />3\"hi-flow pacestter exhaust<br />b&m shift kit<br />catco cat<br />01 T/A rear w/ 3.73\'s and posi<br />1 pc aluminum ds<br />blacked out signals
It should be very easy to put the 5.7 LT1 in your car. Just getting ahold of a nice motor would be the problem. Then again you could just get another 3.4L L32, I saw one in a GM performance catalog for dirt cheap.
EDIT: btw, I know you're probably pretty exasperated now about your situation, but please turn the caps off [img]smile.gif[/img]
[ February 14, 2003: Message edited by: Camarorulz ]</p>-Eric<br />2002 Navy Blue Camaro...Striped and Stalled. 35th Anniversary SS wheels <br />Best ET: 15.384 @ 88.32 on street tires<br />Project Whitney: Goal, 14.0 1/4 by summer 2008.
