Has anyone had a custom PCM done by zzperformance?
I'm looking at getting this done since I have no other way to adjust my speedo for my 3.73s. I just want to know if anyone has had them make a custom for you and how you liked it.
Also, when I'm making the plans for it, what should I consider besides the obvious (no speed limiter, calibrated for 3.73s). Raised shift rpm at WOT? Shift firmness raised? Anything else?
dominic what are you talking about? and if you get it adjusted for 3.73 why would you ned raised **** rpm at wot? and couldnt you ust install a shift kit to get firmer shifts?
Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
