ATTN: Magnus, others.. Looking for wiring pinouts for 98 PCM to Fuse harnesses
Anyone have these? My LS1 is in, using a 98 LS1 wiring harness, and retaining my 98 V6 Fuse Box harness, however, a lot of the wires on the passenger side wheel well connectors (fuse to pcm harness, don't match up)..
Need a bit of help, it's the last thing holding me up
why are you changing the underood harness? Why not use your V6 harnesses.. its a body harness, its not realy engine specific... all you need to swap is your LS1 harness (engine harness) and wire it to the car.
Yes, I am deleting AIR anyway, so I think I will just try plug and play after I do the pink wire splice... and trouble shoot from there. Still waiting on a couple very small parts.
Sounds good. I'll look for you on AIM some time when I'm at home instead of work.
(now if I could only remember my AIM id and password....) [img]smile.gif[/img]
The ls1 mods will be LS6 intake, TEA Stage 2 5.3L o-ringed heads and head studs, a blower/nitrous cam, and used coated MAC headers (I got the headers, cats, and y-pipe for $250 delivered!). And probably VCM Suite. :D
