Need Advise/Help, NOT A CAM Q. - FirebirdV6.com/CamaroV6.com Message Board
  • Need Advise/Help, NOT A CAM Q.
    First: I have 1996 3.8 V6 Camaro w/ Y87 package. I have a few performance mods; see sig and I will also soon have rkpsort headers.
    With that said, I will soon purchase, a Comp Cam GT cam from ZZP (specs: 210°/210° Intake Lift .317", Exhaust Lift .317", 112 LS), #105 Valve Springs, ZZP's modified valve spring retainers, and ZZP's L36 cam install kit (I'm not sure what all it includes). Is there anything else I need to complete the installation?
    Ok, here's where I need help. My car is approaching 93k miles. So, I'm concerned about the effects these engine mods w/ have on my engine. I want to be able to perform w/out anything taking a crap on me. Should I do a full engine rebuild when installing these parts? Or is there just certain key parts I should replace b/c of need or just to be safe. I need advise and recommendations please.
    Also, in addition to installing these parts, should I mess w/ fuel delivery? Would you guys suggest 24 lbs injectors, or a fuel pressure regulator, or something else?
    All help will be greatly appreciated. :D
    Polo Metallic Green \'96 Camaro w/Y87 Performance Package<br /><a href=\"http://www.cardomain.com/id/greenmaro24\" target=\"_blank\">Corey\'s Camaro</a>
    Stock injectors will work fine. Personally, I would be a bit leery of tossing a cam in a high mileage car. I definately recommend replacing everything in the valvetrain except the rocker arms. Get your hands on an autotap and monitor the engine first. Get a feel for how it is currently running. Fix any misfires or knock retard so you are starting with a fresh slate when you do put the cam in.
      While the car is that far apart, I would replace the head gaskets. (You will need to buy those too).
      I would replace lifter, valvesprings, pushrods, etc, just because you can.
      Timing chain and tensioner wouldn't be a bad idea either.
      You will also need an upper intake gasket (for some reason ZZP doesn't include one.) And you need the blue lower intake gaskets, not the orange ones. Make sure they know that.
      1997 Dodge Viper GTS
        3800 performance has a "Cam install" kit for 84 buck and 65 more with the timing chain that would be your best bet,
        like the others said
        compcams ORE lifters
        compcams spings and retainers
        compcams push rods
        if you go the cash i would new main and connecting rod bearings, new oil pump, new rings that way all the major parts of you motor have 0 miles on them and new cam bearings to
        new head gaskets and all the little stuff, and your good to go for 100K more [img]smile.gif[/img]
        www.turbov6camaro.com
        1997 3800 Series II Camaro
          So please help me get a complete list of EVERYTHING I need, and preferably where to get it:
          Comp GT Cam - ZZP
          Comp Cams #105 valve springs - ZZP
          Valve Spring Retainers - ZZP
          GM Cam Installation Kit
          w/ Timing Chain and Tensioner - 3800Per.
          Comp Cams OER lifters - 3800 or ZZP
          Comp Cams Hi-tech pushrods - ZZP
          New head gaskets - ???
          New oil pump - ???
          What all bearings, rings, and lil' stuff will I need to replace? Recommondations and from where?
          Also should I got with a fuel pressure reg. or anything to mess with fuel delivery?
          And should I mess with the ignition at all?
            Try checking out a few sites such as, intense racing, thrashercharged, american muscle motor sports, 3800performance, racenet, and else...
            Good luck with your project!
              dont get the cam install kit. IT is for a front wheel drive l36 and the intake gaskets wont match. You can get a gasket kit from gmpartsdirect for alot cheaper also.
              your stock injectors should work fine.
                Are you 100% sure the GM Cam Install Kit for the L36 with Timing Chain and Tensioner from 3800performance won't fit my 96 V6? It's listed under Firebird and Camaro.
                Come on guys help me finish this list please.
                  yes it will because internal part for L36 are the same just make sure you order it under the camaro,
                  its say fits all l36 1996 to present,
                  make sure you get the L36 one and not the L67 and you will be fine.
                  when slecting the part, make sure its NO on the gasket for that is 6 bucks thats for L67 motors
                    bearings i would get clevite 77. www.intenseracing.com or call around local shop they usally have them i know the clevite make them for
                    Main, cam, and rod (i have all 3)
                    this is from Advaced Auto
                    PN#'s
                    clevite 77 cam bearings- SH1812S 18.99
                    clevite 77 main bearing- MS2022P 66.99 (or summit for $53.39 pn cle-MS2022P)
                    clevite 77 rod bearings- CB1443P 5.59 (need 6)
                    oil pump kit - Melling Engine Parts K195 40.99
                    piston rings "premium" Sealed Power E919K 142.99 (holly ****)
                    just to to the advanced web sit and putin ti your car, and put all this in you car and pinit in then go to your loacl store and get it they got all the gaskets and everything you need
                    i would get the rest of the PN for you but my connect is slower then 56K here in Iraq hope this helps
                      aslmost for got if your going to turbo/boost your car one day get the intense racing head gasekt on there site for 159$ best monye can buy
                        they also sell vaule and everything thing at advance, vavle seat and the works
                          "And should I mess with the ignition at all?"
                          you could go MSD wires, and coils would be nice upgrade for about 200 bucks i have PN# if you need them
                            no not unless your running boost or you can get your PCM programed,
                              Viper you are the man, and don't forget it.
                              I still got a few Q's I'd like for you to clear up please.
                              On clevite 77 cam bearings and main bearings. Are they 18.99 and 66.99 EACH or is that for a set. If for each, how many of each do I need?
                              Also, this confused me:
                              "they also sell vaule and everything thing at advance, vavle seat and the works"
                              Can you clarify please?
                              Also, I don't plan on boosting so I don't think I need the Intense head gasket? Can I get a replacement one from advanced?
                              I was thinking about getting the Taylor Spiro 8mm wires, are the MSD wires better? I guess I'll go ahead and replace the coils w/ the MSD coils.
                              And Viper, are you sending off your PCM to see if wester can tune 96-97 PCMs?
